This is for someone with ambition
i have a bezel that was a work in progress but still needs a lot of plastic work ....it was a 67 with the heater section was replaced to the later style and the hazard light switch blocked out the woodgrain foils that go on 70/1 dashes cover this body work
as well as the radio was blocked off ....it was cut before anyway.....has the piece to fix the corner .....
the gauges are in need of resto ...the speedo is 150 MPH speedo but the gears on the backside have rust and the speedo does not turn.
WHAT i AM LOOKING FOR
72 duster/demon dart radio/heater non- a/c bezel with woodgrain.
