Rallye dash knob radio
1994redram
Oklahoma
I've had my '70 dart project sitting on the back burner the past year or two. I've recently started working on the car and I want to get the interior sorted out. I would like to switch from my standard dash to a rallye dash. I already have a retrosound radio installed, it's a knob style radio. I also have factory A/C.
Did mopar ever produce a rallye dash with a knob style radio? If so, what make/model?
Knob radio in 67, 70,71 for rally dashes
Edit: sorry, I made an error, I think it is 67 & 71
as far as I know all 70 Dart rallye dashes have thumb wheels, but 1971 Demons had almost identical dashes with knobs. both were available with air
My ‘67 Barracuda has the knob-style radio in the rallye dash. I am planning to convert my ‘72 Duster to the same setup.
67 is one year only. Bezel, inst' housing, climate controller, more, are quite different from all other models.
True, but I have a ‘67 dash frame and all other year-specific components, including a dash harness. As long as the dash frame will bolt in, which it should, the conversion should not be a problem.
I have a 67 dash bezel on my 69 dash. I have 71 ac controls, so it is a Frankenstein. It was originally a heat only car I converted to factory ac. If you are not set on correct factory setup, It can all be adapted fairly easily. Just takes a little improvising & a few trips to the hardware store.
70 and up have the flasher switch on the column. Anthere difference for the 70 up owner to do something about
