[SOLD] Rallye Dash with AC Under Dash Harness
67fish383S
Spring Lake, MI
Cleaning house. I bought this along with a cluster assembly to keep as a spare. I don't think I'll end up needing it, but I have no problem keeping it on the shelf either. If you need one, it looks complete to me with the exception of the flasher circuit, which was cut. All I ended up with was the flasher switch connector, which unfortunately is in the pictures, but I intend to keep it. It is just two blade connections, so it would be easy to replace. Everything else looks to be in good condition and all original, including fuse box, bulkhead, and all other connectors. It is out of a '67 with AC, but should also work for later years with a rallye dash, as the flasher switch was the only difference. $150 plus shipping from Spring Lake, MI 49456.
