Rallye dash
ibleedmoparts
Milton, Fl
Is it possible to install a rallye dash in a non rallye car? I am unsure of how the gauge sset mounts...just an idea
Floyd
The wiring harness would likely have to go with it but there are some members here that have done it. I think Jim Lusk is one.
The harness is different and the dash frame will need a ton of trimming.
I did it. And AdamR is right about a ton of trimming.
Do you have a wiring diagram or did you use the original dash harness? Any pictures of the cut? It looks good...I just may put one in mine
No pictures unfortunately. I didn't have the wiring for the ralley dash. I had to figure out what wire went where, which I wouldn't recommend. I would find the ralley dash harness if you can. I didn't have a wiring diagram.
Fred B
there are all of 3 wires to back out of the round main panel connecter. They move to the 3 pins on left printed circuit board of a rallye panel. Camparing the 2 panels side by side helps determine which 3 that went to what need to be relocated so they still goto same.
Just from memory , one is the left turn lamp wire.
