Ok DusterDoug and MadDart, its all steel but has 2 Jaz front buckets, no rear seat, radio, heater, and wiper motor or front bumper (as of now), mild steel 6 point bar with home made 2" by 2" .120 frame connectors. Id gander to say maybee 3100 lbs with out driver?
8 3/4 with 4.10s and spool, 002 and 003 springs with stock shocks(my down fall?) my pinion angle might be 8* also, i believe the tire dia is 27.75. Has a 8" convertor ,not sure of flash yet. Low gear Pro Trans 904 no trans brake.
.040 '71 360 with a 4340 eagle crank and good rods, The LA RhS heads were were done by Erik Jones in Lancaster, Factory LS1 2.02 and 1.625 valves, bowls blended and guide bosses smooth a bit on the intake side, milled to 58.8 ccs. Not sure of flow data on heads. Hedman 1 /78 headers with 3" flowmaster exh.
Ross forged quench pistons yeiding around 10.7, custom ground Comp Cams hyd roller with .519 in- .549 exh 254-264 at .050 on a 106 installed on 101.3/4 or should i say 102. Hughes 1.5 rockers with factory mopar banana groove shafts, std victor intake with a OTB holley 80496 950 HP. ohh also i have a 1" four hole spacer , maybee a open might be better. heres a few pics.
