norshorblufish
By the Big Water
I wonder if the owner sports a mustache like this to match the setup on his car.
Been very dry here for a couple years as well, same issues with grassland fires, plus wildfires in forested areas, we do get a fair amount of runoff from the mountains in the spring, and have hundreds of miles of irrigation canals along with reservoirs to help with agriculture.We haven't had a large amount of winter snow for several years, as bad as I hate dealing with it, it's really needed, it's been horribly dry here, our rivers, ponds,creeks,marsh areas are all dried up.
then, we have horrible grassland fires farmers need to grow crops, aquifer is empty, bad deal all around ..Just don't need it all at once !
we are setting 200 year snow falls every week
That's got Rock Farm repair writ allover it
To replace the gas tank in a 54 Chevy wagon, I had to unbolt the shackles and lower the rear end. Shop manual said, “use a floor jack to raise the rear end to reattach the shackles” - lying bastards. The arch of the springs made it impossible. After a lot of cussing and head scratching, I devised a solution the guy above would like.
Thinking outside the boxTo replace the gas tank in a 54 Chevy wagon, I had to unbolt the shackles and lower the rear end. Shop manual said, “use a floor jack to raise the rear end to reattach the shackles” - lying bastards. The arch of the springs made it impossible. After a lot of cussing and head scratching, I devised a solution the guy above would like.
I put a rock bar under each rear wheel with a large rachet strap under bar. Then I lowered the car and watched to see when the springs stopped compressing.
At that point I wrapped the rachet strap and pulled the spring down until I could reattach the shackles. Sketchy as hell. But it worked.
If that’s a 10mm on that ratchet it will be missing for generations.lol.RJ
