I’ve researched and am still finding threads/posts going back to about 2010 or so regarding “burr finish” I want to say I’ve seen posts/comments even older than that maybe as early as 2003? where the term “textured” is used. Speed-Talk shows up quite often, along with countless others and from what I’ve garnered is that it does make a noticeable difference in throttle response, times slips at the track, and with jetting. As to HP/torque gains that, again based on the myriad of comments out there, ultimately depends on each combo. Seems it’s agreed that any gains won’t show on the flow bench.Interesting...what's the general consensus on How Much the Gains would be ? You think its worth removing an old Holley Strip Dom, and grabbing new gaskets?
I can tell you the time it takes to do what I’ve done vs using sanding rolls to polish to say a 60 grit finish, polished etc is much less.
I’ve mentioned earlier in this thread my reasons for trying a different approach to attaining a similar result. It was simply that I didn’t want to source a pricey burr, try to bend it just so etc. Like mentioned by RRR, whatever gets the job done.
Having the manifold clamped/held down is a must to be able to bear down on the burrs, really get them digging into the material to get the troughs and sharp/rough texture.
