wazoo64
Just installed a 727 with reverse manual on my 67 coronet. Is there a ratchet shifter out there that will plug into stock console?
Put a heat sleeve on the cable. Will save a lot of grief . you can get one at Advance or Auto zone.
Is the heat shield you guys using specific to the shifter cables or is it just a generic heat shield for wires and cables in general? Is the shield like spark plug boot protective material?
You're welcome but credit must be given to SB69GTS. He was the original poster. :glasses7:
Would like to see some pics of how that turned out.I put a turboaction cheeta shifter in the stock location, in the console on my 68 barracuda. was a bit--h, lot of rigging, but works very well, glad I went to the trouble.
Between the Hurst Pro-Matic or the B&M Quick Silver any one have a preference? I think either one would work with a little finagling (that a word?)
