hotrodhoodlum
X Nostalgia Drag Racer
Any one install a RB Motor in 1965 A Body . What can I expect ? Its has a 318 in it now. I dont have a problem cutting out inner fender wells and shock towers .
Thanks
Thanks
I don't know if this is verboten or not..........
go to www.bigblockdart.com and you will find the answer to virtually question you will have. The archives have a lot of pictures showing what members did when they encountered issues.
The big problem you face ( yeah , me too and I stayed with a small block ) is using an early A body. Much tighter than '67 and up.
Anything can be done........it is up to us to decide if it is worth doing.
But you are not alone on this one.
Yes I have been researching this mess lol It looks like a good reason to stock up on 360 blocks and make some HP
Thanks
Holy Fenderwells, Batman!!!
Saw that car years ago,
You should see a full pic of it,
It was baddazz looking
what headers are you runningYou don't have to cut the inner wells its just a tight fit I have an RB 440 in mine. The other is my buddy Pats with a B1 in it.
that is the baddest early dart i have ever seen!are those fentons in front?You don't have to cut the inner wells its just a tight fit I have an RB 440 in mine. The other is my buddy Pats with a B1 in it.
