threewood
Putting together my 440 with 440Source Stealth heads, Crane ductile rocker arms 1:5 ratio. Installed valve spring height is 1.880", Hughes solid lifter cam, lift is .552".
This is the rocker arm swipe at rest, base circle, no pushrod interference. Toward intake side. Will shims be enough to move it closer to center? Raising it a bit will also fix an issue with the exhaust retainers kissing the underside of the rocker arms. Does anyone make wedged shims to move the shaft closer to the exhaust side?
