[SOLD] Re-Built Lower Control Arms
R4Sedan
Larry
Weeki Wachee, Fl
I have For Sale A Pair of Lower Control Arms. These Are from my '67 Barracuda. I re-built these using Moog bushings. I took a close up of the Right one cause it's a little dinged, however it doesn't affect how the control arm functions. They also come with new re-bound bumpers. I soaked and cleaned these in a parts washer then cleaned them in Evaporust. You can paint them. I was gonna put an aftermarket sway bar on my 'Cuda, but scored a complete Factory set-up. So I'm passing this on to someone else. They should fit '64-'76 A-body,but please do your research.
I want $100 plus the Ride.
I prefer M/O or Check. But I can take PayPal, If you pay the 3%.
Thanks, Larry in Spring Hill, FL 34608
I am interested in the control arms.
Could you check what shipping would be to 58503, Bismarck ND
Thanks in advance
FYI.
When installing the lower control arm pins, MAKE SURE you support the backside of the inner sleeve they press in. Use a socket inserted through the hex side. If you don't the inner sleeve presses out the back of the already installed bushing. You'll be installing a fresh set of bushings again!
