Schneiderman
My 1970 duster with a 225 was having warm start problems so I re-routed the fuel line and relocated the fuel filter behind the alternator as I have seen suggested. But I still seem to be having the same problems. I might be a little better. The car starts and runs perfectly fine when cold. If I drive it around, park it for a little while, and start it while it's still warm, it will be hard to start, and it will run like crap for a few minutes. It even stalls sometimes.
Since I got the car last year I've replaced the air filter, spark plugs and wires, rotor and cap. What do you think might be causing warm start problems? I still have not done timing or a valve adjustment (I don't use the car much and I haven't found time to do these yet). I don't know if that has anything to do with my warm start problem. The car runs fine otherwise. In fact I was surprised to find today that after 178 miles of driving in a mix of highway and city with heavy traffic and some spirited driving, I got 21mpg- and that figure was arrived at after I filled up this morning then again this evening at the same exact fuel pump.
