Ready to fire the 340
Does It has 340 stamped in the drivers side of the block. Because the info I have is conflicting with that#
It has 340 cast into the casting number on the drivers side of the block. I could probably scrub off the pad under the drivers side head and find the numbers there too.
Only a mopar musician would attempt that cleaning :thumbsup: here looking over your shoulder waiting on the next post brother :popcorn:
Throw’er in the caustic soda hot tank, come like new.
Oh how I wish I still worked at Stahl Manufacturing in the plating room. I had access to caustic soda ranks, phosphoric acid tanks, sulphuric acid tanks, cadmium plating, anodizing, phosphate plating. Oh, the things I could do now!
That# should have a P or H in it
Front of the block stamping
