psi_duster
Member
For anyone who's interested in this.
After he went into them for the second time, there was a comment along the lines of those heads needing a ton of grinding.
After the third try, they’re still flowing less than aluminum SM’s that have had the seats cut and a minor quick blend in the bowls.
Plus the aluminum heads have a lot more spring installed height to work with, which makes it easier to set the heads up for higher lift.
It’ll be interesting to see what happens after he steps up to the bigger intake valves.
Although, I’m with Brian in not being a fan of running a 2.02 valve hanging out past the edge of the 1.970 seat ring.
Basically, I look at it as an exercise in trying to make “race parts” out of stock replacement parts, which almost always ends up requiring way more work than if you just started out with a more suitable part right from the start.
I'm actually going to be porting a set of these soon. It's going on a two barrel dirt track engines so the porting will be different than if it was for regular four-barrel type racing but either way should be interesting to see what we find.
Sure one of the other few heads available would be easier but I think it's an excellent experiment seeing what's possible if someone had a specific need or desire to run a stock looking iron casting. Or if for example no other heads even existed for your engine. Hard work horse power.After he went into them for the second time, there was a comment along the lines of those heads needing a ton of grinding.
My feelings exactly. But….. whatever the customer wants….Basically, I look at it as an exercise in trying to make “race parts” out of stock replacement parts, which almost always ends up requiring way more work than if you just started out with a more suitable part right from the start.
He's probably got some twisted idea of making the engine look like a junkyard 5.9 magnum with an intake and headersMy feelings exactly. But….. whatever the customer wants….
The customer(s) have a thought in their head, whatever it may be, and choose the head and go from there.
(As your acutely aware of.)
The customer doesn’t always make the wise choice.
Are there any flow numbers available ?
For sure, I've learnt so much from Charlie's videos. No BS and the extent of the editing is the pause button on his phone.His videos are straight forward and not full of random jargon or over produced with music ect. I like that.
It is a damn shame they didn't keep making them the same as the NZ heads.Be interesting to see what happens with the bigger valve.
My one experience with the NZ head was that cutting the seat for the 2.02 valve, using a back cut 2.02 valve, along with a quick bowl blend and tweaking the SSR got the flow to over [email protected] lift.
Between .550 and .600 the flow fell off(turbulence), and at .600 it was down to 250.
No work on the guide boss or pinch area.
It’s strange that when the heads started coming from Vjina, that they didn’t make the ports exactly like what the NZ heads were.
Strange right?!?! As in, WTF?! Why wouldn’t you make the exact copy? They just about directly rip off everyone else without care or concern on anything. Why not this head? They ripped the **** out of Edelbrock without give a ****!Be interesting to see what happens with the bigger valve.
It’s strange that when the heads started coming from China, that they didn’t make the ports exactly like what the NZ heads were.
Exactly, it was a big winner.It is a damn shame they didn't keep making them the same as the NZ heads.
