It all started out with what was supposed to be a simple selector shaft seal change, but now I think I killed it! First I dropped the pan and drained all the fluid. Then removed the valve body bolts (never done any of this before) and I found out about the E-clip that holds the valve body in. Got it off and dropped the valve body. Changed the seal and put it all back together with a new MP deep pan. Filled the fluid to full, started the engine, put it through the gears and back to N. Put in more fluid till I had it just under full and the moment of truth.......... Reverse, nothing. Drive, nothing. Any gear, nothing. I can feel it clicking through the gear so I think I got it all back together right. So I look under the car, fluid is leaking out and the kickdown is stuck all the way on, like if the car was floored. Come to find out one of the pan bolts is stripped and I must have put one of the little arms on wrong because the kickdown was catching on the gear selector. So what I'm trying to find out is, could the kickdown being pressed all the way in make the trans not go into gear? I dropped the pan again and found this rod-bolt thing that is right beside the kickdown button is just kind of sitting there loose. I can push it back on there and it will stay but if I wiggle it it will pop out about 1/8" and is loose again. Did I break it somehow?!?! 72 904 transmission. Pic #2 is the rod thing loose.
