R ReneDK Member Joined Jun 21, 2019 Messages 12 Reaction score 1 Location Denmark Jun 30, 2019 #1 Hii Is it normal that you an pull the wheel a little bit in and out on the rear axle?
RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member Joined Jun 7, 2010 Messages 104,993 Reaction score 102,748 Location Georgia Jun 30, 2019 #2 Yes. That spec is .006-.010 I believe. It is adjustable on the right hand axle if it still has the original tapered roller type axle bearings. Get you a factory service manual for it and it outlines the procedure very well.
Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,415 Reaction score 5,289 Location PA Jun 30, 2019 #3 Nope. Check the end play, it is adjustable. Remove the passenger side wheel & brake drum for access.
