SSing
Not happy with my old goat now... why isn't she one bit cooperative here.
Picture shows measurement from center of rear axel, to lower front lip of rear right wheel well.
Well, 15"+ is fine, but on the other side it´s more than half an inch less.
I haven't done any cross measuring yet, but really see no issues with the body what so ever.
Axel can only bolt up in one way, so am I just unlucky with poor assembling?
And yes, I know a quarter of an inch is probably what you will find on other ´68 FB´s, but this...
I need every bit of an inch, since I hope to be able to run 29,5" tall slicks.
As soon as I can have an extra hand, I´ll do some cross measuring.
Putting shims between leaf spring front hanger and body, is the best way to cope with this problem, or...?
If you thing 15"+ is more than most ´68 Barracudas? Yes, I all ready have a 10 mm aluminium plate to shim out (front hanger) the rear leaf spring bolt eye, since rear schackel did not have an acceptable angel.
