68'barracuda Well-Known Member Joined Sep 13, 2012 Messages 257 Reaction score 26 Location Nocona Texas Aug 13, 2013 #1 Could anyone tell me if a 1973 -74 b body rear axle will fit a 1969 Fury
Inertia Well-Known Member Joined Feb 4, 2011 Messages 5,987 Reaction score 3,466 Location Victoria B.C. Canada Aug 13, 2013 #2 These links helped me a lot http://www.moparts.org/Tech/Archive/axle/16.html http://www.mymopar.com/index.php?pid=73 The A body axle length is incorrect in the second link. hope it helps
SGBARRACUDA ROY Legendary Member Joined Dec 7, 2006 Messages 22,009 Reaction score 10,664 Location PLANT CITY FL. Aug 13, 2013 #3 Should work the B is about 1" or so wider than the Polara rear.
72bluNblu FABO Gold Member FABO Gold Member Joined Nov 28, 2008 Messages 15,132 Reaction score 9,274 Location NorCal Aug 14, 2013 #4 The perches will have to be moved, the '71-74 B rear perches are at 47.3", the Fury's will be at 46". Otherwise, the B rear is only an 1 1/8" wider, so, just a bit over 1/2" per side. No biggie.
