aaadave
hi all, i've got a 72 dart slant 6 with 71/4 rear and 9'' brakes. it has no gear whine, but has a bad low growl at all speeds like bad wheel bearings. i have another 72 dart parts car with a good 71/4 that came with a 318, so it had the 10s''. the 10'' drums are missing and cant find any, so i thought about swapping the 9'' drums, backing plates and hardware to the donor rear. now my question. i wanted to try some new wheel bearings on my rear to see if it would fix it and if not, i would swap my axles with the new bearings in the donor rear. every place i checked says the 9''brake wheel bearings wont fit the 10'' brake axle housing. is this right or am i missing something? i thought the only difference in the 72 71/4 rears was the brake size. thanks for the help, dave.
