rear brake drum assembly
Tadams
Tadams
nc
Another question. Took all back apart and re assembled with new parts. I need the small that runs around the cable guide. I need to replace this but can't locate one for a 65 Barracuda Formula S. One parts place said he could get this for a 68 but not a 65. Anyone know if this may interchange. Has 10 in brakes.
Thanks for your help
The small what?
sorry, the drum brake self adjuster cable for 10 in brakes.
It doesn't show the cable for a 1965 Barracuda with 10" brakes but it does show one for a 1965 Dart with 10" brakes and it is the same as a 1968. I have ran in to this issue before with the Barracuda not being listed.
On line shopping. the only store I didn't check has the correct part. Should called NAPA no how. In stock locally and only 2.43 each side. Pick up in the morning.
Thanks so much for the info. You guys are really awesome to help.
