Rear brakes
n8ling
Langford BC
Ok I have 69 cuda 10" rear drums 8 3/4 rear
I Cannot find a set of drums to work infact all parts stores are showing listings for 10x1 3/4 shoes and only 9" drums ???? What the heck is going on , can anyone help with a part # or anything????? Old drums measure 10" w/ 3" height
I did have a guy find drums from2000-06 Mazda mpv 10" x3" tall 5 x 4.5 bp and they are so close but just to tight. My axle have been drilled to lbp and I don't mind drilling drums if I could find some!!!! Anything would help at this point thanks
I've been on the horn cause I've just had enough Discs are sounding better by the minute. Thanks for such a quick response
Here is some info I saved following the above post a few weeks ago
Rear 10” drums:
Centric 122.63044
www.autoatlanta.com, $83.82
CarPartsKing, $67.86
These are SBP, 7.25" rear. I don't know if the same for 8.75" rear. Also, if you try to order, may get the standard "out of stock".
I might be too cheap for these, so I have been thinking of cutting the lip off some front drums. Looks like it would fit, and I have some with single lips. Fronts are ~$22 ea.
Raybestos/Dana still makes the small pattern stuff. If you can find their number just call and they can get you a part #
