I hadn't noticed until now that my passenger side rear quarter window does not roll up into the groove on the upper weatherstripping seal. It sits outboard too far and has started to curl the weatherstripping over. This is mostly noticeable at the rear corner. The window itself is also very hard to roll up from the bottom position. What is the best way to fix the alignment problem and sticky window? I've never messed with the window mechanisms before.
Also, what is the chrome moulding piece that runs along the top inside of the rear quarter just outside the rear quarter window glass? It looks like it probably had felt on it at one point. Mine looks pretty beat up and also appears to be falling off. Where can one get these and how hard are they to change out?
