keith9291
I have a quick...do the direction of the front and back pivot bolts matter?
Heres what happened, its been warm here in St Louis the last few days and I decided to install my new set of XHD springs. I got a new media blasting cabinet and blasted all the parts and painted them with zero rust. I thought I new what spring went on what side and set up the shackles accordingly. The front pivot bolt had the nut going inward and rear shackle had the bolts pointing outward. Right before I got the springs in place I called Mancini real quick and found out I had the springs on the wrong side. I swapped sides real and bolted them in place. Today I went out put the shocks and tires back on and lowered the car to tighten the pivot bolts and noticed I didn't switch the way the bolts went in when I swapped sides of the springs. Will this make a difference? I noticed there is a spot in the frame rail for the front pivot bolt to go into.
