Rear Sway bar on narrowed rear?
DARTDALE
Hoxie AR.
Does any one know if one of the new adjustable anti- sway bars from Helwig [6907]{ the one which mounts on the frame rails] will fit a Dart with a narrowed 9 inch?As regards the front sway bar 5906 [Helwig] will it adapt to a 72 Dart that did not have a bar installed from the factory?
If the springs are in the stock location, the 6907 will have no problem with a Ford 9"- it will clear a Dana 60. If the springs have been moved inboard of the subframe rails then the 6907 will not fit. The front bar 5906 includes brackets to mount the sway bar to vehicles w/o the factroy sway bar.
Theres a guy on B block Dart that fab up a rear sway bar for his relocated springs using one from a ford truck.
