rearend
unknownsnake
Mason, MI
so finally got rear end from junk yard and im ready to get show on road. what are the measurements i need to tell them to get my rearend narrowed?
Its a 8.75 out of a 73 new port and its going in a dart sport:clock:
...right, but that chart will tell you how much you need to narrow the rear end to work on your Dart Sport.
Thanks
OldMoparsRule!
Stock A body flange to flange is 52 5/8".
Be careful, there are some HORRIBLE charts floating around with incorrect lengths.
That's what you want to cut it, even if it's going in a 73+ car to use stock type stuff.
I'd cut it shorter, run BBP axles and deeper wheels with less offset.
