dpmalibu
Professionally rebuilt 340 motor
Come hear it run. Still in car.
Built by legendary engine builder Charlie Weston (from Piscataway,NJ) according to the guy I bought car from.
Block casting # 2780930-340-2. Date code 5-31-72.
Approx 1500-2000 miles.
Mild cam . Smooth idle(couple steps above stock, specs unknown).
"J" casting heads.
2bbl intake/carb.
Runs excellent no smoke, leaks etc.
Asking $2000 B/O
Freshly rebuilt "X" heads
Mild porting (intake runners opened up a little (gasket match) /bowl work)
2.02/1.60 valves
I have all the paperwork for the heads (components used, flow numbers, etc). Heads are off the motor and reay to go. less than 200 miles on them.
heads are good up to .540" lift
Asking $1000 B/O
Rebuilt Torque-flight 727 trans
Built by Royal transmission in Spotswood, NJ.
Stock rebuild; low miles (same as motor)
Asking $450 B/O.
340 High performance factory exhaust manifolds
Cast Iron
Driver side casting # 2863553.
Passenger side casting # 2863549.
Asking $400 B/O.
Take everything for $3850 (Motor, trans, manifolds, "X" Heads)
Motor,trans and manifolds asking $2850 B/O
Motor,trans(no manifolds) Asking $2450 B/O
Drivetrain will be in car until mid July then I will video motor running and part out the car. Located in Hatboro,Pa
"J" casting heads.
2bbl intake/carb.
Asking $2000 B/O
2.02/1.60 valves
Asking $1000 B/O
Asking $450 B/O.
Cast Iron
Asking $400 B/O.
