Rebuilt 360 short block
oldkimmer
Kindersley, Saskatchewan,
I picked up a basically free LA 360 short block from member Max1196. Thanks buddy!!! It’s .040 with dished pistons. Crank is turned .010. Resized factory rods with ARP bolts. Kim
Put EFI and a big turbo on it and go LS huntin.
Even with the 8 ish compression? Ki
Advancing cam some and more timing advance will be in order! I personally run 3.91's out back for more neck snapping take offs. Not too terrible with 28" tires on highway. Don't do much highway anyway.
I took it apart to check it over. Just a factory type dished piston so probably 8-1. Rods were resized with ARP bolts. Crank was turned .010 on rods and mains. Kim
I’ve got a lightly used in excellent condition Isky 280 Mega hydraulic on a 106 LSA in its Original box doing nothing that might you be interested in?
