69B-Cuda
I rebuilt the 904 in my 69 Barracuda. I also put a TF-2 shift kit in it. It seems to run and shift fine.... most of the time. Sometimes, more after I drive it for a while, it does not want to upshift if I have it in drive. I will stay in 1st and seem to freewheel if I let off the gas. If I move the shifter down into 1st, then into 2nd, it shifts into 2nd fine. Sometimes in drive, it shifts to 2nd but not into 3rd. If I put it in neutral and back into drive, it is then in 3rd.
Kickdown is adjusted fine, fluid level is fine, I flushed lines and cooler out when I did the tranny.
Is there something wrong with the governor or some little piece of junk in the valve body?
Searching threads on here, it seems like the governor may be the guilty culprit. I did take it all apart and clean it real well when I had it all apart. I did not see anything wrong, grooved, bent, or sticking.
