[SOLD] **REBUILT** A,B,E, Body Disc Brakes 4 1/2" Inch Bolt Pattern.
hemi71x
Rancho Cordova, CA
I have rebuilt a disc brake system that is used on the A, B, E, Body, Dodge, and Plymouth automobiles.
These are the 4 1/2 inch, big bolt pattern brakes.
Commonly known as the 10.80 inch rotor diameter, disc brake system.
All the 70-74 E Body Barracuda & Challenger cars used these brakes.
73-76 A Body Duster, Dart, Demon, Valiant cars used big bolt pattern brakes, similar to these, but different style calipers.
70, 71, 72, B Body cars, Charger, Coronet, Super Bee, Road Runner, GTX, and others, used these brakes.
These can be used on 72 and earlier A body cars to convert to big bolt pattern disc brakes, or B & E Body Drum brake cars, to Disc brakes, or any year B Body car that you want to.
The disc brake spindles are officially 70-72 spindles, that i am using the modern replacement one piece rotors, that are now available for this brake system.
Calipers i have rebuilt, and are known as the "Pin Type" caliper.
All the hardware for them are there, and nothing's missing.
Gravel shields, are nice and straight, and aren't rusted pieces of junk.
Spindles, and caliper mounts, all the nuts and bolts are there.
The lower ball joints are nice and tight, with intact grease boots.
Everything to do a disc brake conversion on your car.
I have done all the hard, dirty work for you, in rebuilding, these brakes.
You just need to have the mechanical skills, know how, to do the conversion on your car.
This is what i have been doing as a now retired, professional auto mechanic, to give me something to do with my time, during my day.
Selling everything at $650.00
That's the price. No "offers" trades, for anything else.
Cash and carry, if you pick up in person.
A lot of 100 dollar bills will do, or i can FEDEX out the parts, for whatever it will cost to your zip code.
It will be quite pricy, as this stuff is Heavy, and i won't be sending boxes of feathers, or marshmallow's, out to you.
I can be contacted at.
Nine One Six Eight Five Two One Seven Five Eight.
Call only during the evening time hours of 5:30 - 7:30 pm, PACIFIC TIME, if your interersted.
I won't call you back, if you leave a message on my machine during any other time of the day.
Don't like calling the tire kickers, look -e- loo's, non serious buyers, so if you want to talk to me, it will be on your dime.
Thank's a lot.
Jim V.
The majority of these parts ( spindles, gravel shields, caliper mounts, nuts & bolts, bearings, seals, are original parts to the 71 Cuda that i purchaed new, back in the day.
Wether that means anything or not, just letting you know what i originally got the parts from.
This is the very last brake system that i can rebuild, put together, for resale.
Out of parts, no more, all gone.
Get this last set, while you can.
Hello, Jim! Once again, I hope you don't mind my newbie questions, and I hope you don't feel that I'm wasting your time. I wrote some questions on your other for sale thread for your Kelsey Hayes 4-piston brake set. I have a 1969 Barracuda, all stock, manual drum brakes. I'm interested in upgrading to some good disk brakes. Would this setup here be better than the small bolt pattern Kelsey-Hayes system you're offering as well? I'd prefer better performance to staying with the small bolt pattern, as I will probably need to replace the rear axle as well (it's a 7 1/4"), so I suppose I'll have to do away with that weak link, so I can go to big bolt pattern in the rear and different wheels. So would I also need any other parts to make the switch with these rotors/spindles? What would you recommend? BTW, this is my first Mopar product and I don't know jack squat about them....trying to learn. Thanks for your time.
Mike
Poland!
Sure would hate to give you mailing quotes into your country.
Yes, sir! Thanks for all your help in the decision-making process. Indeed, I am trying to work this out, and I am leaning more toward this set than the Kelsey Hayes setup. I have not forgotten out you, Jim, nor am I ignoring you. :)
hi
I have the Kelsey hayes brakes
I'm looking for the rotor 4 1/2 bolt pattern any place I can get it ?
I have the small bolt pattern rotor now
