Well. Ach. I've got a '65 Barracuda that I've installed a rebuilt 360 into. I thought I'd be all smart and replace the wiring harness, move to a Mopar Performance electronic ignition, and Toyota (Nippon Denso) alternator.
The harness I bought is from Year One, part #HU352AM, which is supposed to be a '65 harness modified to use electronic ignition.
The electronic ignition is a Mopar Performance (orange box) that I bought from Summit Racing, part #P3690426.
Here's my issue.
First, I'm not sure which ballast resistor I'm supposed to use. The 2-prong or 4-prong ballast resistor? The Year One wiring harness came with two plastic connectors that connect directly to the 4-prong ballast resistor. But the instructions that came with the MP ignition unit show diagrams using the 2-prong resistor, as do the various write-ups I've seen in this forum. It looks like the question to use either the 2 or 4 prong resistor has to do with the control box you have, which is supposed to be either a 4 or 5 wire connector. Mine has 5 wires, but the diagrams show that the green/red is unused.
Now I'm confused. If I use the 2-prong resistor, it seems perfectly clear how to wire it up all up. No problem. That is, until I need to figure out exactly what to do with the plastic molded electrical connectors (two blue wires on one and brown/blue/red+green on the other).
Yikes.
Help?
Here's my issue.
Yikes.
Help?
