Redneck Fluid Vacuum
Duggie
Tacoma WA
Needed to upgrade to synthetic PS fluid after tube headers.
Drilled a couple holes in this hard side jug lid to get it done. 1/4" hole for the tubing. 1" hole for the shop vac. The vacuum in the jug pulls the PS fluid through the tube and doesn't saturate the vac's filter.
Great idea, made one similar to bleed brakes using your engine vacuum .
