burrpenick
'69 Barracuda
Car is located in Tallahassee, FL, just 12 miles south of the GA border!
1969 Plymouth Barracuda Coupe. 318 4V, expertly built with big valve 360 heads, 340 cam, double row timing chain, windage tray w/baffle in oil pan, 340 intake, genuine 340 EXHAUST manifolds and turbo mufflers turned down in front of the rear axle, Chrysler electronic ignition, trunk mounted battery option, 5 blade clutch fan; performance built 904 torqueflite A/T with Cop car converter, 3.23 Sure Grip Mopar rear gear, Mopar front Disc Brakes, Carter AVS carb; sparse interior....black bucket seats, no rear seat or tradional dash- does have oil pressure/water temp/Amp/Tach gauges (not all connected currently), painted Petty Blue w/yellow and white accents. Mopar 15" CopCar wheels w/new tires, formula S big block front torsion bars, and Formula S 6 leaf rear springs, Addco front and rear sway bars, KYB gas shocks. .
The car was built for the GRM (Grass Roots Motorsports) series that pits entrants against themselves- ala SOLO driving a road course and a 1/4 mile run- ALL ON A set BUDGET limit. This car ran approximately 5 of these races and did OK- and delivered LOTS of fun for the retired/senior driver/owner!
Currently titled in my name (FL) and is fine for street driving- will need some of the lights fixed etc to be truely street legal.
