The thin chrome box in 273's 1st photo is $11 at rockauto. I bought one a month ago for my 64 Valiant. Should hook direct to your factory wiring. The old box (you probably have near master cylinder) is a mechanical relay that switches on and off and thus disturbs your 12 V supply, which is undesired for electronic ignition (and other devices). You should run a ground wire to the case of your ignition box, not rely on the sheet-metal screw like the factory did. That is a very common problem. Indeed, had you asked earlier, most of use would have recommended using a GM HEI module and coil and eliminate the ballast resistor (many posts).
