Good morning all. As a winter project I'm planning on installing the Reilly Motorsports Alterkation front suspension kit on my 72 Dart bracket car. I looked at Hemi Denny's HDK kit, it's a little more expensive and I'm on a tight budget. Last winter I installed Wilwood disc brakes on all four corners. Does anyone here know if the Wilwood caliper mounting brackets that I used on the 73-76 disc brake spindles will bolt on to the spindles supplied with the Alterkation kit? Other than that everything looks like a straight forward bolt on process. Thank you.
