earlymopar
I'm searching for the correct wiring schematic for a relay to ignition coil set-up to provide direct battery voltage to an HEI and be able to have the ignition switch turn off the engine. What I have is a 12 Volt 4 Pin SPDT Automotive Relay 30A/40A like that seen below. I understand the leads that need to be attached but not correct connection points by terminal name.
Thanks,
- EM
Thanks,
- EM
