MoparOrNokar
HammerTime
This is what I did, 1 gauge wire to a cut off switch, from the switch I then ran the wire on the inside across the back seat and then up the drives side (same as the factory did) out the firewall through floor plug to the starter. Next 1 gauge wire from the starter terminal up to the starter relay. The reason for the cutoff switch is I like to kill the power when not in use, like at home, car shows, cruise nights and it makes it harder to steal the car too. I also installed a 1 gauge wire from my transmission to the car frame, you can not have enough grounds. The car starts just as good when I had the battery up front.
I dont know how safe it is but i like the simplicity. The wire size from starter to starter relay is what my original question is about. I kind of understand the other setups but the car will never see the track. Im moving the battery to simply unclutter the engine bay. So if i did this simple setup could i maybe add in a fuse for safety and is a 6 gauge wire enough run from starter to starter relay in the engine bay?
