Remflex Intake/Exhaust gasket
dart4forte
Mesa, AZ
Getting ready to swap on my Dutra exhaust manifolds and an Offy duel 1 barrel set-up on my aluminum slant. I plan on using a Remflex gasket. Will I need to use extented studs or can I get away with using the existing studs? I've had really good luck with the Remflex gaskets on my other Mopar V8s.
My guess would be to use what you have !! I've never had to switch to longer ones for my Offy's !! Only reason I went to New ones was for the bling factor instead of old dirty ones !!
