moturbopar
Hey all, thinking about throwing together a super cheap 318 turbo engine for my truck. I picked up a 318. Did a budget overhaul, been given performer cam, small 204 at .050 and .448 with 1.6 lift. Or I have a crane cam 216 at .050 with .484 lift. I have magnum heads fresh valve job, pocket ported. Air gap intake ( I know its not ideal). also a 600 dbl pump with blow through mods. long tube 1 5/8 headers. Anyways this is going into a 84 dodge d150 (sorry no a body). I want to mount this under the truck behind the trans x member. The turbo I have is probably way too small, but its a t3/t4 hybrid I bought it for my ford 2.3, but is too laggy. has a stage 3 turbine, and I have both a .63 ar and a .82 ar housings. has billet compressor wheel, 58 mm inducer and 83mm exd. Turbo was built for built 3.8 turbo T/A, made 440 rwhp. Think it might make 300 to 350 rwhp?
