Sportman
Member
Hello,
I have a 1974 dart sport 360, with msd 6al ignition. I currently have the ballast resitor removed and the wires jumpered to give me the 12 volt run wire for the msd. I would like to remove the ballast connectors and the old ignition plug from my underhood wiring. If I remove the ballast plugs which wires should be connected together. I have the 7.5 v start wire and the 12 volt run wire jumpered together running to the 6al 12v ign wire at this time. It works, but is there a better way? I am just trying to clean up some under hood wiring.
Thanks for any help.
