I've tried to look it up and have had no success. I am going to be doing my body work Friday and going to be painting my car. Or should I just mask them off and just be careful around them.
I mean the front and rear windshield. The ones looped around broke off and it looks like clips hold them in place and I don't want to break the others.
Depends how detailed you want to be - you'll get a better paint job if you can remove the chrome, less chance masking seams will show. I had to strip mine all down for body work, it's a bit of a learning experience. There's a tool you need or can make that pulls the clips away from the front/rear glass stainless trim so it comes off easier. It looks like an arrow shaped thing that slides under the trim and grabs the side of the clip. I can try and upload some pics later if no one beats me to it. The clips are replaceable, and just screw into the body around the glass, but a lot of times the screw head is camouflaged by years of crud and rust. I removed my glass so I took them all out and they're getting replaced.
