Does anyone have any experience removing the Clutch/Brake Assembly on a 69 Dart? I have removed all the bolts, but the assembly hits a bracket in front around the speedo cable, before the bolts that attach the master cylinder clear the firewall. This bracket appears to be attached somewhere higher up in the dash. Do I have to remove the instrument cluster to remove this bracket or am I missing something simpler? Also I've loosened the steering column and I was hoping to lower it to get this assembly out? Or do I have to remove it?
Thanks for any advice.
