MoparFan
Last weekend I have tried to remove the 360/727 combo of the 78 Magnum that I bougth. Everything that I could think of is disconnect, in fact the whole combo went foward about maybe 1.5" to 2" ... but I was never able to get it out more then that. It looks like that trans won't come out of is rear crossmember.
Other then the 2 bolts, in front of the cross member, linking the transmission to the support, is there any other bolts?
Do I have to remove the transmission crossmember? (because it has some kind of subframe for the whole front on these car, right in front of the trans crossmember bolts)
