You can use plastic cups (made for this purpose) for the tail shaft, instead of using a slip joint. They do not fall out of get in the way. I have a set for different size openings.Wow, never thought about that. I have seen it done (on a lift) on that show Graveyard Cars. However, I have a pretty small 1 car garage to work in and I don't think I will have enough room to do that. Ill look into it this week. Also, I have a plug for the transmission tail shaft.
Thank you.
Don’t forget to install a slip yoke in trans, that oil is hard to get off floorI'm pulling the motor and transmission out of my 1966 Barracuda. It's a 273 with a 4 speed manual transmission. I am going to pull both at the same time, however, it looks as if the pressure plate will not clear the Centrelink. Has anyone had this problem or know if it will make it by the Centrelink?
No I didn't need to remove the center link it cleared it.
Yes, it will physically fit. There are many things that need to be changed or modified though, if you're trying to use some of the 273 parts.I just got some bad news from the machine shop today. My block has a crack in it. Does anyone know if a 360 would fit in my 1966 Barracuda?
Too bad you live on the east coast. My buddy up in WA state has several.I just got some bad news from the machine shop today. My block has a crack in it. Does anyone know if a 360 would fit in my 1966 Barracuda?
Much easier. Less motor mount bracket mods (usually...depends on the year of the block), same pan and pickup, same intake and exhaust ports, and no converter/flywheel rebalance.A 318 LA is a easier swap bolts right up and same oil pan as 273
