ir3333
any body try this with car on jack stands?
i.e no rotisserie....
And wear eye protection.
Harbor Freight sells a cheap pneumatic needle scaler that works pretty good and its safe.
Propane torch. Leave it on, no one cares about your car that much.
I did it on my 70 dart while it was on jack stands. I used a cheap harbor freight heat gun and a putty knife. It worked very well. Just watch out for the lava hot rubber. And wear eye protection. It really wasn't as bad as I thought it was going to be. Oh yeah keep the heat gun at an angle that the under coating won't drop into it.
Is this first, 2nd or 3rd hand information
Just wondering it you have done this yourself?
that looks to be a very clean car,anymore pics?
i had already started this and was wondering what others have done
..miserable job!
Don't play around with this. Put eye protection on and keep it on. A face shield if you are melting it off.
One drip of melted undercoating or aircraft stripper in the eye and you would pee your pants and wish you were dead.
