edb_app
I have replaced all all of these things including th battery and still have the problem of not enough power. Sometimes when I press the brake the car dies. When I have the lights on and hit the blinker the car dies. What could be causing this. A guy at Schucks told me it is most likely a shortage in the wiring somewhere. Where do I start. I also read on here that maybe the NSS wiring could be shorting out somehow. I am leaning more towards that because the clips are real loose and I am not 100% sure how they are supposed to fit. Is it supposed to drop down from the engine and the wiring fit with the clips into the 2 holes on the side of the tranny pan? Than loop over the pan and connect to the switch? If someone could help that would be great. Its really frustrating replacing so many things and the same problem persists.
