Not sure where you are reading power and am assuming that you mean at the positive battery cable. So, I'm doing a wild *** guess and will go with the fuseable link. Are you getting voltage at the fuse block on the main "RED" battery feed. If not it's probably the fuseable link.
i learned the hard way many years ago to disconnect the battery when playing with the electrical.
