Replacement 68 340 four speed cams
My 99.9% stock 340's would run 14 flat go 165 and get about 20 mpg on snow tires with no posi. no o.d. Stock exhaust system. I have plenty of witnesses. There may be some better stuff out there but it always worked for me. Now add 1.6 rockers, 11.0 to 1, o.d. 4.10's headers etc. what would you get today. Add a high-pressure fuel system. Wow just imagine what you'd get out of that little 340 with a 55 year old cam. O, with 55 year old heads to boot. Now ...
165 mph in the quarter mile?
I would assume that the 52 degrees overlap is based on 0.006 lift and not 0.050 just like their duration numbers (or whatever low lift number they used). My Oregon cam card shows 42 degrees overlap.
Right. All the Chrysler stuff was given advertised.
I like my "OLD" simple stuff. I hear people spending thousands to gain .20 in the quarter. I don't get it, when the consistently maters. Chrysler did it right, with DC help.
what was the .1% that wasn't stock?
I for one can vouch for the 340s top end charge. My 73 340 Rally Charger with 78K on the clock hauled me and five friends out to the junkyard one Saturday in 1981. One of the guys in the back, Jeff Clark said "hay Rob, will it bury the 150 speedometer?" I said "I don't know, I ain't tried it yet." Then I firmly planted my foot on the floor and just held there. I had the needle pointing a little past straight down before I lifted. 150 was about at the 5 o'clock mark. The car was all original with the original 73 supposedly "lower" performance 340, stock manifolds and stock exhaust right down to the original mufflers and slotted exhaust tips. I routinely outran a school friend's 70 396/375 Chevelle. Pissed him off so bad every time he demanded a rematch. I remember only once when he got me and it was by a bumper. We all knew that car was faster and quicker than it "should" have been....and it was. It had to be all over 4000 pounds that Saturday with six of us in it. I think their curb weight is a tick under 4000. 3850 or some such? Here's the car. The guy I got it from got drunk in it not once, but twice. Hit a brick mailbox the first time and a brick wall the second time. His dad took the car from him and that's when I paid 300 bucks for the car. We found good fenders, bumper and grill for it in a local junkyard. That's why the fenders are brown. You can see the damage on the hood. That car would slap move for a big car.
i agree.
pretty much everyone grinds it as the AT lift, but with the MT duration and on a 114
(which i think is butt, let the record reflect)
now gimme that factory cam on a 110 and we talkin' it's brie time baby.
Yep,
For what its worth, Schneider ground me a 264/274 .445/.450 222/230@ .050 110 lsa solid for my sons 72 340 auto Dart with 587 1.88's. power brakes and oem exhaust.
That's a different grind than the 4 speed cam. The 4 speed cam was a dual pattern, just like the auto cam. It had more duration though and it may have had more lift too.
Yeah, here it is from @krazykuda right out of the 1968 service manual.
68 340 4 speed cam:
276°/284° duration
.444"/.453" lift
Int open: 26° BTDC
Int close: 70° ABDC
Exh open: 78° BBDC
Exh close: 26° ATDC
Overlap: 52°
Per the 68 factory service manual
here's the spec straight from the DC catalog page
P3412044 68 340 Man.-114 276/284 .444/.453" 112
P3690213 Street Hemi GT-112 284 .471/.474" 109
auto 340: 430/444 268/276
manual 340 (68 only): 444/453 276/284
comp *used* to make a very similar cam to the manual 340 unit. i'll root around in my notes to see what i can find.
most all the aftermarket makes a version of the standard 340/360 4bbl cam. i like the melling piece personally.
Here's the specs on most of the factory stock camshafts for a SB....
I made a spreadsheet of camshaft specs and did calculations forward and backward to check if the specs were correct... I did find a few with some conflicts and was able to correct most of them from doing the math forward and back and checking with the listed specs for the cams...
Do you have the old DC catalog(s)???
Would you mind sending me a copy or pictures of all of the camshaft spec pages for all of the engines and from which catalog (year) that they are from??? Slant 6, SB, BB, & Hemi.... I would love to add them to my spreadsheet... I only have the Mopar Performance catalogs to use for specs, but would love to get the info on the old DC catalogs...
68 340 4 speed cam:
276°/284° duration
.444"/.453" lift
Int open: 26° BTDC
Int close: 70° ABDC
Exh open: 78° BBDC
Exh close: 26° ATDC
Overlap: 52°
Lets see if this is more readable... (For us old guys with 'old eyes'...)
