APK
I purchased a used speedometer, sent it to be restored and calibrated to replace the one in my Dart that was malfunctioning.
I was waiting to swap the speedometers at the same time I was going to do a restored radio swap. Well after waiting for the radio over several months (still don't have it yet...another story rotest I decided it was time to swap out the speedometer. The bad one was "driving" me crazy!!:banghead:
While I was waiting for the radio I kept the replacement speedometer caught up with my actual miles I was putting on the car by hooking a speedometer cable to a drill and running it for the amount of time needed to match the mileage. I usually ran the drill at the speedometer speed of 70 mph and the fastest the drill would get it up to was 92 mph.
This week the garage that I use for repairs swapped the speedometers as they were doing other work. Today I took the Dart out on the highway and the needle would not break the 55 mph mark and I know I was going faster that that. Slowing down the needle did not move then dropped about 10 mph and continued a natural slow descent through the numbers. From 0-50 it seems ok, then next 5 are not achieved as quick.
Any ideas on why now that the speedometer is in the car it can not get higher than 55, when I have been able to do that with a drill? Speedometer Pinion Gear?
The speedometer cable was replaced in Nov 2011.
Thanks for your replies.
