Replacing Fuel Tank, Lines, Tube...Suggestions?
seabee
1537 Paper Street
Hi All,
I've been putting off this project for 3 years but now it is time to get it done. My tank and probably my lines also are cruddy and need to be replaced. I was looking to get a spectra tank and a fuel sender with a return. I also have to replace the filler tube because a PO had used epoxy to connect it to the tank, which leaks. I want to do this once and do it right. Any suggestions or tips are greatly appreciated.
Thanks in advance -Billy
Use a baffled fuel tank, it will stop the fuel gauge from bouncing around in high brake turns etc.
As far as replacing it, hope the tank is almost empty (makes life solo much easier!).
