I bought my '65 Dart about one month ago. The sellers told me it had been sitting for about 4 years. The gas gauge gives various reading so I really wasn't sure how much gas was in the tank. Wasn't sure how old the gas was either.
Last Saturday I took my Dart to a brake shop for an inspection (found one cylinder leaking). On the way I pumped in 2 gallons of Chevron Premium. This was the first time I have added any gas since I bought the car. On the way home from the shop I noticed the car really shaking whenever I'd try to accelerate. Got the car home.
I was wondering if adding the Chevron Premium to whatever was in the tank already was causing problems. Or is the tank suspect? Looks fairly old. Not sure if it's the original or not but it looks like it has been there for a while.
Sunday afternoon the car wouldn't start. Turns over real nice but would not catch. So I looked seriously at the fuel filter and saw a very dark one. See picture below. The one on the right is the one that came with the car. The one on the left is a new one from Oreilly's.
So I put in a new filter. While doing this some gas ran back out of the old filter spilling around. Later I noticed some very orange colored stain on various parts of the fan and lower pulley. The residue left after the spilled gas evaporated. When I touched it it came off like a powder. I'm thinking rust and crap.
So today I siphoned off 10 gallons of gas in an attempt to empty the tank. I filled two 5 gallons gas cans. Whenever I would remove the tube I placed inside the tank it would have little dark colored debris stuck on in. So I'm convinced the tank is full or rust and Lord only knows what else!
I admit that the car not starting may be something else like a bad coil or some other electrical issue.
I'm convinced the gas tank needs to come out! I don't want to try starting it any more until there's a new tank in place and fresh gas in it. I see there appears to be one strap holding the tank in place. The strap is held at either end by a bolt and some sort of attachment. So once I loosen or remove the strap will the tank drop down some? I realize it will still be connect to the gas filler tube and the sending unit. What will be next? Remove the sending unit, using a brass tube and a rubber mallet to eliminate sparks? Then remove the tank from the fuel filler tube?
Any help sure would be appreciated!!!!!!!!!!!
Glenn
Glenn
